Add For Streaming 2 and more Audio track
santer
Member
Hello!
My idea consists in the following:
To add at Streaming a sound recording in different soundtracks:
1) Audio Track 1 = game Sounds, my voice, notifications, Skype
2) Audio Track 2 = Music, songs, radio
After Stream (An example for Youtube) I delete a audio track at number 2 where music with copyright contains, at the same time there are sounds of game and my voice. And later I can add music without copyright.
And you can already *record* multiple audio tracks, so record at the same time as streaming and exclude the music from the recorded video.
@Simes ,
At Live Streaming to make a sound recording in two audio tracks, then to remove video after streaming from youtube. On the working computer, to process video with removal of the second audio track with music and to send anew to youtube?
I actually phrased that badly, what I should have said was that you don't even need to include the music in the recorded video at all.
For example, if you set up your mixer settings in OBS like so:
Track 1: All sounds. Game, Skype, notifications, mic, music.
Track 2: Game, skype, notifications, mic, *not* music
Then you send track 1 to the stream and track 2 to the recorded video.
Depending on where your music is coming from you'll probably need to use some virtual audio cables but this should work.
Not convenient method that after Stream it is necessary to send 4-8 hour video to youtube.
But thanks @Simes , is better so, than without sound will be
