Advanced Scene Switcher
Advanced Scene Switcher 1.35.1
Any suggestions for how to detect if notepad++ has focus? It insists on putting the entire filepath of the open file before the "Notepad++" in the title and no amount of regex suggestions from google like .*Notepad\+\+ seem to work.
I can put in the current full window title and that works if I have that specific tab open in notepad++ but that means I can't swap to any of the other 20 tabs in it. I can't figure out how to make it check for an executable name if possible.
I can reduce the window title to just "[filename] - Notepad++" but even that doesn't work with the regex so it's not a problem with a window title that is too long
I assume you've tried .*Notepad\+\+.* and .*Notepad.*? The second might catch some other things too, but if you don't have any of those, then it's fine.
I'm about to have an aneurysm I spent so long on something that should have been so simple last night. Now it's working and unless it was an actual bug that needed a reboot to fix I have to assume I kept adding a space at the start as it's the only thing that's making the behaviour from last night happen.
Both of your suggestions and mine are working now even with the huge full filepath names in Notepad++ after relaunching obs and notepad++. Thank you for your help, apparently the good vibes fixed it.
Hi, I may or may not have said that I had issues with Asc and might have posted it, but I tried your update and it works. The old behavior froze obs at start up. I would delete it and obs worked again. This fix leaves me puzzled though. It did freeze at start up today, so I tried safe mode to see if it was Asc. I did safe mode once or twice then Advanced Scene Switcher works. Thanks!
Is there a way to have this control your mouse? Ideally it is like autohotkey with button clicks and coordinates, but prefer to keep it in this program.
My use case is, I have 1-4 streamers in a discord channel at once, and once someone dies, I would like to switch to another player quickly - but I know if I can set a macro up in ASS, I can have my bot look for a twitch channel command like "!switch1" and it will go and control my mouse, click the proper sequence to then swap to another player and make it full screen.
It would let me go AFK from the stream a bit easier knowing that people can swap to other players while I am gone.
Thank you as usual for this amazing tool.
Unfortunately, the plugin does not support that currently.
Maybe you could use the "Hotkey" action instead?
I am trying to figure out if discord has one, but I can't find it on reddit. I just posted in their subreddit to see.
Thanks for the fast reply, you are a gem.
Is there a way to have this control your mouse? Ideally it is like autohotkey with button clicks and coordinates...
That's generally a bad way to do things, because user interfaces change, and then the mouse automation misses the button. It may not do anything because it hit the space between buttons, or it may do something completely unexpected that causes you headaches to figure out, because now a different button is in the same place and it did that instead.
On Linux, I use xdotool to move the mouse, issue system hotkeys, etc., but only for large, somewhat hamfisted things. Like, putting the mouse on a particular screen (the entire screen is my target, not a particular button) so the next app that the same script starts will appear on that screen. (Adv. SS' Run action points to the external script, not the tools directly) Or I can move an existing window to a different screen, bring a particular one on top, etc.
xdotool does all that and far more, on Linux, but it's all coarse actions. No automating a UI with it. It *will* automate a UI if you put in that much detail, but like I said above, the next update may break it spectacularly. Far better in that case, to use hotkeys like Warmuptill suggested, or whatever you can find that's going to stay put.
i want to use my MIDI controller to act as a video switcher
i managed to make "macros" in ASS to select each scene in preview
i managed to activate the transition slider with another plugin (OBS-MIDI-MG)
but i'm struggling to just have a button on the controller just switch the scene from the program to the preview, please guide me
I thought it should have been simple: just add a MIDI condition and let it auto-detect. But it doesn't seem to see the Korg nanoKontrol 2 that I just happened to have lying around:
The "Reconnect all" button doesn't fix it, nor does restarting OBS.
QLC+ does see and use it, on the same machine, so I know it works.
the configuration to have the MIDI controller talk to OBS is working
i'm trying to figure how to make that midi command (note on 49 in channel 1) press the transition button for me
i already setup all 8 scenes to be called in the preview via MIDI buttons, i just need the part where i can tell if note on 49 on channel 1, press the transition button in OBS in the studio mode
Maybe this then?:
Hello Warmuptill,
First of all, congratulations and thank you very much for this plugin, it's amazing!!! I have primarily been using Linux Mint 22.2 XFCE with OBS Studio 32.0.2 for live streaming, and since version 1.32.X of Advanced Scene Switcher, OBS abruptly closes whenever I try to create a new condition in a macro.
Alternatively, I have been using version 1.31.0 of your plugin.
Hi @Warmuptill ,
Version 1.32.4 resolved the issue I described earlier. However, I have now detected that it is no longer possible to correctly save "scene item visibility" actions when the item is a vertical scene inserted as a source in another vertical scene.
I have also detected that when creating actions to enable/disable filters in vertical scenes, the Advanced Scene Switcher does not relate the filters to the respective vertical scene.
I performed the tests on Windows 11 Pro 25H2 and also on Linux Mint 22.2 XFCE, and the results were identical.
Is there any possibility to save the login with twitch permanently? in streamer.bot it works. but in adv scene switcher, I need every 1 or 2 month renew the login.
