rmanaka
Hello, great tool! I'm new to both OBS and this plug-in but I think that there is an error in the Import, Export functionality in System.
I create a backup where I use three memory slots in LT1 and no memory slots in LT2. I export the configuration and save as backup.txt.
When I import the backup.txt file, the old LT1 Memory slot 2 (M2) Name is restored to LT2 MS1, LT1 M2 Info is restored to LT2 MS1 Info, LT2 Info is restored to LT3 MS1 and the old LT2 Name restored to LT3 MS1.
The old LT1 MS1 Info is restored to LT2 Info.
The logos are not restored correctly, in fact LT1 MS2 is not saved and MS3 is not saved.
I've tried to edit the backup.txt file but it seems to be more difficult than at first glance because the parameters are not exported in any sorted order that I can determine.
I'll try replacing the delimiters with a NL, sorting the file, making changes and then changing the delimiter back to a comma and see what happens!
Oh, and deleting a memory slot is inconsistent...I hold the mouse click on a memory slot until it turns red but upon release most of the time nothing happens.
Other than my import/export issue, FANTASTIC work... Thank you!
