Make sure to use exactly the same format when entering the paths for both the control panel and the browser source. Under windows I use file:///C:/path/to/html%20files/control%20panel.html
file:///C:/path/to/html%20files/browser%20source.html
hello stephanvs, path is the same :/ still not working
I was also having issues with the lower thirds not working on a fresh install of OBS 30.1 and this plugin on Windows 11. I tried testing other browser sources and found out that none of them worked. That lead me to this brief video on YouTube: https://www.youtube.com/watch?v=XLJ4rOj5sMY
TL;DR - the solution is to go to File -> Settings -> Advanced, scroll all the way to the bottom, and then under Sources, make sure the checkbox for Enable Browser Source Hardware Acceleration is disabled.
The error indicate that the lua file has an error in it. You could try to (re) download a new installation of the lower third plugin. If the error persist, then it needs to be fixed in the lua file
GrumpDog, Could you guide me on how to create/ask a question on this forum, specifically on Animated Lower Thirds created by NoeAL's? I see the envelope @ the top right corner, but that is email for specific people. How to post a question like you? What button to push to start posting a question here? Thank you.
2 Questions: 1st: Please guide me on how to post/ask my own question - I only see the option to reply to other people's posts. Where is a button or option to post/ask a question to the general forum? 2nd: My question is I am unable to add Google Fonts to the Animated Lower Thirds created by NoeAL. The font box shows .... or "><, or > This happens despite my having checked the Shut Down Source When Not Visible, & Refresh Browser When Wcene Becomes Active. Thank you.
I am unable to add Google Fonts to the Animated Lower Thirds (LT) created by NoeAL. My LT's font box shows .... or "><, or > This happens despite my having checked the Shut Down Source When Not Visible, & Refresh Browser When Scene Becomes Active in OBS settings. Attached is a screenshot of LT's font box highlighted with a red box.
Has anyone got a solution for making the background into a different shaped box rather than a simple rectangle or an image (png / svg with transparency to add some variety?
Other wise works perfectly on Mac intel OBS version 3.1.2
Great plugin. Thanks
Amazed by this script! Great work @NoeAL !
If I could make one feature request, I would love it so much if I was able to create more than one Browser Source in my scene to add a second, third, etc. lower third in the scene at the same time. I have guests on my channel and it would be great to give them the identification they deserve.
Thank you for all the hard work you have clearly put into this.
Hola, instale la actualizacion del obs 30.1.2 y cuando inslate el plug in , me sale error del script para los hot keys :
[lower-thirds_hotkeys.lua] Error calling script_load: [string "C:/Program Files/obs-studio/Animated-Lower-Th..."]:436: C:/Program Files/obs-studio/Animated-Lower-Thirds/lower thirds/../common/js/hotkeys.js: Permission denied
[lower-thirds_hotkeys.lua] Failed to call hotkey_pressed for hotkey_pressed: [string "C:/Program Files/obs-studio/Animated-Lower-Th..."]:436: C:/Program Files/obs-studio/Animated-Lower-Thirds/lower thirds/../common/js/hotkeys.js: Permission denied
alguien sabe porque ?
gracias
Hi gang
Needing some insight to why the animated lower thirds is not showing on the preview. Downloaded and installed successfully and have entered text in both field text boxes. Both switches are turned on and the lower 3rds browser is on top of the other inputs. The blue frame in cycling on and off as it should but there in no animation in the preview window. OBS is running on a computer with I5 processor and onboard graphics. I have the lower thirds installed on 2 other computers with I7 processors and the lower 3rds is working as it should.
So 2 questions.
1) Is it the computer with the I5 processor or
2) Is it the on board graphics of said computer?
Have watched tutorials on Youtube and followed the instructions.
Hi gang
So 2 questions.
hey there...if you have not fixed issue yet, this should work...I had the same problem. 1. add a new browser to your scene. 2. uncheck local file top left. click "browse". 3. got to the obs animated lower thirds folder, then click on lower thirds folder. 4 *Important* on the "browser-source.html" file, HOLD THE SHIFT KEY AND RIGHT CLICK - SELECT "COPY AS PATH". paste into the file area and REMOVE quotes "" from the beginning and end of the paste. Scroll down and check boxes for "Shutdown source and Refresh Browser" - click ok. This should work, it worked for me after much rresearch.
It's funny that the description of the plugin says it doesn't work on Macintosh, I'm here on Mac, I had to do some "magic" but here's the plugin working perfectly without any kind of problem with MacOS Catalina and with version 29 of OBS.
Thank you very much Noe for the great work! Excellent resource for creating high quality content.
Es curioso que digan que no funciona en Macintosh, estoy aquí en Mac, tuve que hacer algo de "magia" pero aquí está el plugin funcionando perfectamente sin ningún tipo de problema con MacOS Catalina y con la versión 29 de OBS.
¡Muchas gracias Noe por el gran trabajo!, excelente recurso para la creación de contenido de alta calidad.
Tal vez no lo encontré, pero ya esta funcionando para Mac OS? lo instalé pero no funciona...seria cool si pueden subir un video tutorial para Mac
Gracias!
Si te interesa una consultoria (de pago) te puedo ayudar, si no lo quieres pagar siempre puedes hacerlo solo y aprender
Good day NoeAL,
This is an amazing plugin. I'm testing it right now and I was wondering how this be used in conjunction with "Social Stream Ninja" plugin.
May I request any thoughts on that?
Thank you
can someone help me, ive copied the file path as it is on my sysyem and the control panel exactly as its labelled and i just get this
