Ashmanix Countdown Timer
Ashmanix Countdown Timer 2.2.0
Hey, unsure if the plugin is or is not capable of this need, but I figured I'd ask.
I've got it installed, 3 countdowns, 1 per amount of hours (1, 2 and 3)
I'm using touch portal to control elements on my stream, so I have a button to make 1 hours countdown appear, 2 and/or 3 depending on my needs.
I set the 1, 2 and 3 hours in the 'Countdown' settings and I see a few choices on hotkeys in the OBS Studio settings, but I either don't see an obvious one, or it's not possible.
Basically I'd like Touch Portal to turn on the source of the countdown, which it is, as it's toggles the 'Text (GDI+)' that the countdown is using, but then when I assign a key combo to one of the key hotkeys available on the countdown, none of them reset the counter to it's set value in the settings, i.e. the 1, 2 or 3 hours?
Is there a way to reset the time of the countdown from the hotkey combos, to reset the timer/countdown back to it's default I've set on it's relevant settings?
So, say I press a button on Touch Portal, it would send a ALT+CTRL+1 over to OBS Studio and then OBS Studio tells your plugin to reset it's time on timer 1, for example? [obv keys/combos, etc are just examples]
Ideally, I'm wanting an little countdown to tell people how long on the particular game I'm playing is left
Thanks for your time.
Regards
PJ
There is a current but where pressing the period time set button doesn't set the text on screen. I need to look at this. Once fixed you should be able to use the hot key to set a time and it will set the timer again and update the text on screen.
I've also noticed the descriptions for the hotkeys are only showing default variable names instead of the actual text descriptions. What language have you set your pc to? It looks like the text translations aren't being found by the plugin.
Currently I have my machine set at my default language, unless you are talking about somewhere else in the system? like OBS Studio?
And which one of the current choices I am seeing should be the one that will reset the timer to it's set time in the countdown?
I have my config set now, so that when I'm not needing the timers, they are hidden, but the button press on my Touch Portal shows the 'Text GDI+' for me, then all I need it is resetting back to the initial time per timer. I've also got a local timer on my gaming pc (dual pc streaming setup) that beeps down my ear, independent of that, it's only for the viewer to realize and not thing about asking to join the game as we'll be switching very soon.
Your language seems fine, not sure why the translations aren't coming through...
The hotkey to use is SetHotKeyCountdownDescription. That is the one that will set the timer, then when you start it will start from the time and show on the text.
Thanks, got it all setup now, had to set 4 buttons, one to reset all the timers, and then one for each hours I want.
Tested and they all work.
if ya do update and you want me to check if and when I update the display, displays correct just drop me a message.
Ashmanix updated Ashmanix Countdown Timer with a new update entry:
v2.1.1 Update
This update includes the following changes:
  • Fix - Reset Not Setting Source Text
Important WIndows Installation Note​
Installation on Windows now requires manually copying the Windows plugin folder into the C:\ProgramData\obs-studio\plugins directory.
If you have an older version of the plugin that was installed using the previous Windows installer, you must remove those files first. Otherwise, they will interfere with the new...
I'm having a problem. I installed it and I have a timer window stuck attacked to the top-left of OBS. I can't move it or affect the size or position in any way. Under Docks if I enable Countdown Timer I have a second, non-functional one that shows up in the usual place. I suspect I have files of an older version still around but I haven't been able to remove them all. SteamUP says that I have an outdated version, 2.0.1.0, installed, even though I've extracted the folder for the latest version to C:\ProgramData\obs-studio\plugins. Any ideas?
Try following the instructions here: https://ashmanix.com/wiki/doku.php?...in#windows_install_older_plugin_versions_note to remove all the old files for the plugin.
I've tried this and it doesn't seem to work. I scoured the appropriate program files and programdata folders for any files or folders related to the plugin. I even searched the C drive for "countdown" to find anything relevant. For whatever reason I can't get the plugin to stop showing up in the OBS plugin manager. If I enable it there I get a non-functional window.
Have you tried going to the View OBS menu and selecting Reset UI? I've had to do this before when sometimes for some inexplicable reason the plugin window ends up somewhere hidden or impossible to select.
Adding the option to set a timer to start as soon as a stream is started isn't needed per say, but would really be so much easier when using a timer for ex a starting soon screen.
I think this issue was posted here several years ago but it doesn't seem it was ever solved.
On my Windows pc, when using Studio mode, the timer is frozen in the Program while it continues in the Preview.
I have tested it with the April version, the August version and the most recent version. They all have the same issue. Also tried it with the last 2 versions of OBS. The timer works fine when you don't use Studio Mode.
Anyone knows why it's like that in Studio mode only and how to fix it? I need to use Studio mode as I need to switch video files during my livestream
Just downloaded and have been testing to use for my church who is going mobile this weekend. Is it possible to request an overrun feature? as in if the count down gets to zero or count up timer gets passed the set limit it keeps going anyways? We often use countdowns and then goes into negatives so the speaker knows how long they went over time.
I'm trying to install this, but the instructions don't make sense. It says:
Step 1 - Main Plugin Files​
Copy the plugin folder, in this case named obs-plugin-countdown to the following folder location:
However, here's what my OBS folders look like.
There is no folder simply labeled "plugins". I tried pasting the obs-plugin-countdown into the obs-plugins folder, and it didn't work. I tried making a new folder called "plugins" within the obs-studio folder and pasting the obs-plugin-countdown folder into the new "plugins" folder, and it didn't work. I tried pasting the obs-plugin-countdown folder into the 64bit folder where the other plugin folders are, and it didn't work. What do I do? How do I get this working?
View attachment 117812There is no folder simply labeled "plugins". I tried pasting the obs-plugin-countdown into the obs-plugins folder, and it didn't work. I tried making a new folder called "plugins" within the obs-studio folder and pasting the obs-plugin-countdown folder into the new "plugins" folder, and it didn't work. I tried pasting the obs-plugin-countdown folder into the 64bit folder where the other plugin folders are, and it didn't work. What do I do? How do I get this working?
Ignore this. After posting it I found that OBS now has a built-in countdown timer, so I've gone with that. I tried to delete the comment but I guess there's a timer on when you can do that and it expired. I suppose the question should be answered anyway in case anybody else comes along who wants to use this plugin but ran into the same problem I had.
Hi, the screenshot you've shown shows the OBS folder in the Program Files folder on the C drive. My instructions point you to the plugins folder in ProgramData on the C drive. It's been a while since I've checked on Windows but I think this is a hidden folder. It's a subtle difference. I away from my Windows PC but I'm expecting the folder structure to still be obs-studio > plugins in the ProgramData folder. If there is no obs-studio folder then you can create it and then inside that new folder create a plugins folder. You should then be able to copy the unzipped plugin folder into there and it should (hopefully) appear in OBS after a restart.
I'm sorry the installation process is such a pain. I use the plugin template code provided by the OBS team as a basis for my plugin. In the last it would compile an installer which would auto install the files. I updated the template code and they took it out as it was causing issues somewhere. It's made installation of the plugin manual (which is a pain in OBS in my opinion).
I'm glad you were able to use the built in countdown timer in OBS. If you still have issues trying to install the plugin don't hesitate to message again
Is the date format on the dock customizable? I want to spell out the month or at least change the order from DD/MM to MM/DD. TIA
There isn't a way to customise the date time format in that field, at least not in the plugin itself. I've just realised that I've set the display format to a UK dd/MM/yyyy...
I haven't worked on the code for a while but the next time I have a look I'll try to implement local timezone default formatting.
I'm assuming you're in a timezone where you use MM/dd/yyyy?
Yes, I was hoping to see a MM/dd/yyyy format. Appreciate your considering my request.
