atkAudio Plugin
atkAudio Plugin 0.34.8
thats odd, since it was regression of previous issue, and after the fix it's working again, at least here
I've setup a portable version of 33.0.0-rc1 with the only plugin being the latest atkAudio 0.35.0 and I'm still getting the choppy sound. What version of VLC media player are you using? I can't think of any other variables.
Can we have labels for the midi control mappings?
I'm using your midi control to map a korg nanoKontrol2 with 8 banks of fader, knob, mute, record and solo controls as well as media controls, marker, cycle etc..
In some cases one control is mapped multiple times across a number of scenes leaving me with over 40 mappings to keep track of and know which one to select when I need to clone from one or change one. Can we have a label field so I can say "Fader 1", or "Next Track Scene 3" vs "Next Track Scene 5"?
regards,
David
regards,
David
https://github.com/atkAudio/PluginForObsRelease/releases/tag/0.35.0 try this, updated with label field.
The plugin seems to be preventing my OBS (latest versions of both, btw) from starting up after a recent Windows 11 update.
Only suspicious thing I can find in the OBS log is "20:37:07.518: Failed to load 'en-US' text for module: 'atkaudio-pluginforobs.dll'" but that file seemingly hasn't been modified on my PC since August.
UPDATE:
It seems to be conflicting with VoiceMeeter somehow, as closing that makes it work
