Question / Help Audio Issues with OBS Studio
I have a 2 PC stream setup using a LGP for my capture card. My audio is feeding from the speaker output from my game rig to the audio in/out of the LGP to my mic input of my sound card on the stream rig. This is a workaround due to the audio issues of using the Video Capture Audio source in OBS. I can see the audio source indicators moving and I have tracks set as necessary for multitrack recording. Problem is OBS isn't sending audio to Twitch and when I record locally, WMP doesn't have audio. I can take the same file and import it to Premiere 2015 and the audio tracks separate and play normally. My steam audio outputs to track 4 and all tracks are checked on 4. My record is set to record to 1,2,3,4. I'm at t a loss. BTW, OBS Standard processes the audio through LGP Stream Engine fine so I know audio is patched to the rig correctly.
That log doesn't show a stream/recording session...can you do a quick recording, restart OBS, and then upload your "last" log file?
Also, can you take a screenshot of your advanced audio settings, as well as your streaming and recording Output settings?
Here's everything
  • 2015-09-04 16-15-21.txt
Looks like you're missing the Advanced Audio Settings (click the gear next to the Mixer window).
Well, WMP isn't working probably because you're missing codecs. It should play correctly in VLC (and you can select which audio track to play). But you're saying the stream isn't playing anything at all?
I don't know the specific one. I stopped using WMP in favor of VLC for a while now. You can try downloading a codec pack like K-Lite. Just be careful of bundled crapware, whatever pack you download.
