Blurred video even with 6000bitrate
loboshow
That's expected. 6000kbps isn't actually all that much, and the encoder you're using isn't all that great -- that generation of nvenc is only going to be about as good as about the "veryfast" preset on x264, with a little bit more macroblocking.
It's the foliage and rapid movement that destroy the encoding quality. High contrast, high motion. It needs a LOT more bitrate to look "good".
Try changing the preset from Quality to Max Quality. You may be able to squeeze out more quality from those bits with 2 pass. If there's encoder overload, rendering lag or game issues, change it back. That log also shows 5000 kbps.
