C64 Stream
C64 Stream 1.2.0
chrisgleissner
chrisgleissner submitted a new resource:
C64 Stream - Stream your Commodore 64 Ultimate to OBS Studio
C64 Stream​
Stream your Commodore 64 Ultimate or Ultimate 64 to OBS Studio.
Features​
  • Seamless integration as a video source in OBS Studio for real-time streaming.
  • Direct connection to Ultimate's network interface - no capture cards or composite video needed.
  • Automatic VIC-II color space conversion ensures authentic Commodore 64 video reproduction.
  • 16-bit stereo...
chrisgleissner updated C64 Stream with a new update entry:
C64 Stream 0.8.0 - CRT Retro Effects
GPU-accelerated CRT retro effects with user-extensible presets
  • Simulates look and feel of a traditional CRT monitor.
  • Supports scan lines, pixel geometry, blur, bloom and tint.
  • See attached images for all default effect presets.
  • Short video of the raster line effect: https://www.youtube.com/watch?v=QWOqHJwHt8s
Granular recording control for capturing raw video, audio, frames, and network/plugin events
C64 Stream 1.0 - CRT Afterglow Effect and Custom Color Profiles
C64 Stream 1.0 is a milestone release focused on improved CRT realism, configurability, and robustness.
CRT phosphor afterglow effect
Afterglow simulates the persistence of phosphors on real CRT displays. Bright pixels fade gradually instead of disappearing instantly, causing moving objects to leave a subtle, time-decaying afterimage. This improves motion realism without introducing blur or smearing artifacts.
The afterglow effect is fully customizable and has been...
C64 Stream 1.1.0 - Remote Control, Keyboard Capture and Effects FIlter
C64 Stream 1.1.0 is a substantial feature update focused on remote control, automation, keyboard input, and bringing C64 Stream’s CRT effects to more OBS sources.
Remote Control and C64Script automation
  • Control a C64 Ultimate directly from OBS.
  • Play local folders, files stored on the C64 Ultimate, songs, programs, and disk images.
  • Automate playback workflows, including HVSC song length support.
  • Use reset controls from inside OBS.
  • Added C64Script...
C64 Stream 1.2.0 - Easier Device Switching, Matching Colours and Smoother Audio
C64 Stream 1.2.0 improves everyday streaming and recording from your C64 Ultimate or Ultimate 64.
  • Automatic device discovery: Find devices on your network at startup and switch between saved profiles. If discovery fails, check that your firewall allows OBS Studio to access your local network.
  • Smoother switching: The current picture stays visible until the next device starts sending video.
  • Matching colours: Select Palette → Follow device to use your...
Will you include an Ubuntu 26.04 LTS build using the official OBS PPA? The current deb is not compatible. It tries to uninstall the official PPA's obs-studio and all the working plugins.
