Random23456
Help! I recently installed OBS on my new PC and I also download composite blur, but whenever I try to blur the background by inverting the mask it just doesn't work. Could you please help?
Hi @Phoenix_025Just anupdate:
After a little bit of testing, I have managed to get it working, but its not ideal.
e.g If i have Blur A and Blur B on the same scene. Then It would forget the Keybindings or set them all to the first one for all of them meaning If Blur A was Key t and Blur B was key u, then after a restart they would all be t or they would be forgotten.
However to get around this, If you
Blur A on scene 1 Key 1 and Blur 2 on Source 1 Key 2 and Blur 3 on Source 2 Key 3
Then and only then will it remember the previous keybinds and not overwrite the old ones.
This release includes the following bugfixes:
It also includes the following new features:
- Fixes a bug where sources used for blur masks would not properly load upon relaunching OBS.
- Updates the zh-CN localization files with new fields added in 1.5.0
- Adds move transition filter transition support (thanks @Exeldro)
I've not seen an issue like this before. Can you please post a log file link so I can see what is being loaded? To do so, restart OBS (so the log is fresh), then go to `Help` --> `Log Files` --> `Upload Current Log File` and then post the URL that it gives you. This will help me to troubleshoot/figure out what might be happening.This plugin is not working for me. I can see it in the filters but when I add it, it just makes my source disappear and the preview window is simply a blue square. I'm not sure what I'm doing wrong but it is not working on any source I try it with.
Correct. Being an experimental renderer, not all shader features have yet been implemented, and it seems that Composite Blur (along with most of my other plugins) are using features that are not yet compatible. I fully plan on supporting metal, though I can't guarantee anything until the renderer is finalized (in a future OBS version).At present, this plugin doesn't work at all with the Experimental Metal Renderer on OBS 32.0 (still seems to work fine with OpenGL renderer). If I have add it to a source and make the filter visible, then the source becomes invisible seemingly regardless of the filter settings. Any chance it might be updated to work with Metal?
Ashmanix's blur filter plugin works on Metal if set to "Box Blur" or "Simple Gaussian Blur", but not when set to "Fast Gaussian Blur", in case that context helps at all.
Hi @mstout -I installed on OBS 32.0.1. When I invoke the filter, the camera image no longer appears.
I do not have a quality GPU which may be the cause : Intel UHD Graphics 770 (an on motherboard gpu)
I have both 64 bit and 32 bit installed.
Is there something I can do?
Thank you
This release bring OBS 33 compatibility to the Composite Blur plugin.
Note: For Windows and Linux, please download the file that denotes your version of OBS. E.g., for the Windows Installer, if you are running OBS 33 download `composite-blur-1.6.0-windows-installer_OBS33`, and if you are running OBS 30-33 download `composite-blur-1.6.0-windows-installer_OBS30-32`. Also note- this version is compatible with OBS 30+. If you are running OBS 28 or 29, please download one of the previous...
Hi @v_cifi-I don´t know why, but if I will add this as a filter, my source completely dissapear ..
Sorry you're having issues with the install. Its possible that Windows Defender has flagged it on your machine (its happened in the past on random people's installs, though usually it is more clear that Windows Defender is what is causing the issue). Its one of those tough "it works fine on my machine" issues which makes it hard for me to troubleshoot ☹️.Getting "This installation package could not be opened. Verify that the package exists and that you can access it or contact the application vendor to verify that this is a valid Windows Installer package" both times I've downloaded, unzipped and tried to install the OBS30-32 version.
