Decklink Output Filter 1.2.0
So what is the benefit of this plugin if it can only output the video of that individual source without it's own audio?
Also there seems to be an added video delay using this plugin. When I output with a decklink using Tools - Decklink Output there isn't a delay, but with this plugin there seems to be a delay. Is this a known bug or is it just me?
Hello, I am trying to get this to work with OBS 27.1.0 on a Mac under Big Sur with a Decklink Duo 2 connected via Thunderbolt.
Is it supposed to show up under FILTERS? Because I can`t seem to find it there after installing. Thanks in advance.
I'm confused, the plugin says it outputs individual scenes but the known issue is that it does not output the individual scene. So from a philosophical stance, am I in the exact same state of consciousness regardless if I install this plugin or not? Seeing as how it does not do what it says? Or and I just totally confused here?
Just to understand what this plugin does:
I have 3 scenes if I add a filter to each scene , with this filter I can tell OBS to output that particular scene to a specific decklink output ?
Something like
Scene 1 - filter to sdi output 3
Scene 2 - filter to sdi output 4
Scene 3 - filter to sdi output 5
Did I understand it correctly?
I'm having out of sync audio-video when I use Ultrastudio HD Mini, sometimes is almost in sync but not always. Do I need to switch to RGB or something similar? For graphics its perfect (with not sound) but with people talking its a mess. TIA
cg2121 updated Decklink Output Filter with a new update entry:
OBS Decklink Output Filter 1.2.0
Updates​
  • Improved performance by rendering on GPU instead of CPU
  • Fixed issue where output would not automatically start when OBS is loaded
  • Fixed issue where output would stop working properly when parent source is not active
Donate​
PayPal - https://www.paypal.me/claytong2121
Patreon - https://www.patreon.com/cg2121
GitHub Sponsors - https://github.com/sponsors/cg2121
I am a little confused. This build is only a few weeks old and maybe I'm missing something but I have installed it like any other plugin filter and it seems to not show up in the filters at all. Not too sure what I am missing here but I'd say broken maybe??? Unless the developer has any ideas, this OBS vet is completely lost with this one. Sucks because I don't want to use Vmix if I don't have too. This would be perfect....if it works.
Could someone clearly indicate at which version of OBS this plugin work? I'm trying newer and older once (both the OBS and the plugin) and seeing only mismatch. It never works :(
