Just recently, I came across a problem recording a Valorant stream. And in general, when starting OBS, the FPS of the game drops to a minimum of 60-80 frames, with my stable 200-300 FPS usually.
I'm have
CPU - I5 12400F
GPU - RTX 3050
RAM - 8GB ddr4 (x2)
I have already found a similar question on the forum, but it was asked in 2020 and the solution that helped the author of the post, unfortunately, did not help me.
Unfortunately, I can't know which log file it is, it might be useful, I hope for your help, thank you in advance.
I'm have
CPU - I5 12400F
GPU - RTX 3050
RAM - 8GB ddr4 (x2)
I looked at the logs and found what I think is causing your issue.
00:45:18.803: [game-capture: 'Game Capture'] attempting to hook process: VALORANT-Win64-Shipping.exe
00:45:18.806: [game-capture: 'Game Capture'] init_hook_info: user is forcing shared memory (multi-adapter compatibility mode)
00:45:18.819: [game-capture: 'Game Capture'] capture stopped
It seems like OBS is having an issue finding Valorant, I would suggest using windows capture and making sure Valorant is in fullscreen and see if that works.
