Bug Report Fullscreen Projector Window Cut in Half on OS X
fhill2
On OSX 10.10.5 when i CTRL click the Preview window, Fullscreen Projector> and choose my capture card the preview window starts half way down the screen and the bottom half of the window is cut.
On the streaming computer's OBS, Under the Projector Window' (Source) and Projector Window (Preview) dropdown where you see the monitors you have available to choose from, the dimensions of the capture card's "screen" is 1080 x 520, which should be 1080 x 920.
The capture card is the Avermedia Live Gamer Portable HD.
The picture attached is the recorded image off the capture card on the 2nd PC.
Is anyone else having issues like this? I read a few days ago that someone said they saw the same thing but with an external monitor, although i am unable to test with one at the moment.
I have attached the log of the OBS session.
What i did: loaded OBS up and then FullScreen Projected to the capture card. then copy and pasted the log
19:43:03.299: CPU Name: Intel(R) Core(TM) i7-4960HQ CPU @ 2.60GHz
19:43:03.300: CPU Speed: 2600MHz
19:43:03.300: Physical Cores: 4, Logical Cores: 8
19:43:03.300: Physical Memory: 16384MB Total
19:43:03.300: OS Name: Mac OS X (NSMACHOperatingSystem)
19:43:03.300: OS Version: Version 10.10.5 (Build 14F27)
19:43:03.300: Kernel Version: 14.5.0
19:43:03.303: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
19:43:03.333: OBS 0.13.1 (mac)
19:43:03.333: ---------------------------------
19:43:03.333: audio settings reset:
19:43:03.333: samples per sec: 44100
19:43:03.333: speakers: 2
19:43:03.405: ---------------------------------
19:43:03.405: video settings reset:
19:43:03.405: base resolution: 1920x1080
19:43:03.405: output resolution: 1920x1080
19:43:03.405: fps: 30/1
19:43:03.405: format: NV12
19:43:03.407: Loading module: coreaudio-encoder.so
19:43:03.407: ---------------------------------
19:43:03.408: Loading module: image-source.so
19:43:03.408: ---------------------------------
19:43:03.410: Loading module: mac-avcapture.so
19:43:03.410: ---------------------------------
19:43:03.411: Loading module: mac-capture.so
19:43:03.411: ---------------------------------
19:43:03.413: Loading module: mac-decklink.so
19:43:03.413: No blackmagic support
19:43:03.413: Failed to start search for DeckLink devices
19:43:03.413: ---------------------------------
19:43:03.415: Loading module: mac-syphon.so
19:43:03.415: ---------------------------------
19:43:03.416: Loading module: mac-vth264.so
19:43:03.429: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
19:43:03.429: ---------------------------------
19:43:03.431: Loading module: obs-ffmpeg.so
19:43:03.431: ---------------------------------
19:43:03.432: Loading module: obs-filters.so
19:43:03.432: ---------------------------------
19:43:03.433: Loading module: obs-outputs.so
19:43:03.434: ---------------------------------
19:43:03.435: Loading module: obs-transitions.so
19:43:03.435: ---------------------------------
19:43:03.436: Loading module: obs-x264.so
19:43:03.436: ---------------------------------
19:43:03.438: Loading module: rtmp-services.so
19:43:03.438: ---------------------------------
19:43:03.439: Loading module: text-freetype2.so
19:43:03.442: =====================================================================
19:43:03.442: output 'simple_stream' (rtmp_output) created
19:43:03.442: encoder 'simple_h264_stream' (obs_x264) created
19:43:03.779: AAC encoder bitrate mapping:
19:43:03.779: 20 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 24 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 28 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 32 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 40 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 48 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 56 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 64 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 72 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 80 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 96 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 112 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 128 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 144 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 160 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 192 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 224 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 256 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 288 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: 320 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
19:43:03.779: encoder 'simple_aac' (CoreAudio_AAC) created
19:43:03.779: output 'simple_file_output' (ffmpeg_muxer) created
19:43:03.779: Service '' not found
19:43:03.779: service 'default_service' (rtmp_common) created
19:43:03.779: All scene data cleared
19:43:03.779: ------------------------------------------------
19:43:15.360: coreaudio: device 'Soundflower (2ch)' initialized
19:43:15.360: source 'Desktop Audio' (coreaudio_output_capture) created
19:43:15.363: coreaudio: device 'Built-in Microphone' initialized
19:43:15.363: source 'Mic/Aux' (coreaudio_input_capture) created
19:43:15.408: source 'Display Capture' (display_capture) created
19:43:15.408: source 'Scene' (scene) created
19:43:15.508: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
19:43:15.567: == Profiler Results =============================
19:43:15.567: run_program_init: 12461.5 ms
19:43:15.567: ┣OBSApp::AppInit: 1.399 ms
19:43:15.567: ┃ ┗OBSApp::InitLocale: 0.56 ms
19:43:15.567: ┗OBSApp::OBSInit: 12392.3 ms
19:43:15.567: ┣obs_startup: 3.852 ms
19:43:15.567: ┗OBSBasic::OBSInit: 12233.6 ms
19:43:15.567: ┣OBSBasic::InitBasicConfig: 0.178 ms
19:43:15.567: ┣OBSBasic::ResetAudio: 0.088 ms
19:43:15.567: ┣OBSBasic::ResetVideo: 71.361 ms
19:43:15.567: ┣OBSBasic::InitOBSCallbacks: 0.007 ms
19:43:15.567: ┣OBSBasic::InitHotkeys: 0.061 ms
19:43:15.567: ┣obs_load_all_modules: 37.117 ms
19:43:15.567: ┃ ┣obs_init_module(coreaudio-encoder.so): 0.004 ms
19:43:15.567: ┃ ┣obs_init_module(image-source.so): 0.002 ms
19:43:15.567: ┃ ┣obs_init_module(mac-avcapture.so): 0.004 ms
19:43:15.567: ┃ ┣obs_init_module(mac-capture.so): 0.003 ms
19:43:15.567: ┃ ┣obs_init_module(mac-decklink.so): 0.084 ms
19:43:15.567: ┃ ┣obs_init_module(mac-syphon.so): 0.004 ms
19:43:15.567: ┃ ┣obs_init_module(mac-vth264.so): 13.29 ms
19:43:15.567: ┃ ┣obs_init_module(obs-ffmpeg.so): 0.014 ms
19:43:15.567: ┃ ┣obs_init_module(obs-filters.so): 0.005 ms
19:43:15.567: ┃ ┣obs_init_module(obs-outputs.so): 0.002 ms
19:43:15.567: ┃ ┣obs_init_module(obs-transitions.so): 0.003 ms
19:43:15.567: ┃ ┣obs_init_module(obs-x264.so): 0.002 ms
19:43:15.567: ┃ ┣obs_init_module(rtmp-services.so): 0.198 ms
19:43:15.567: ┃ ┗obs_init_module(text-freetype2.so): 2.937 ms
19:43:15.567: ┣OBSBasic::ResetOutputs: 336.575 ms
19:43:15.567: ┣OBSBasic::CreateHotkeys: 0.026 ms
19:43:15.567: ┣OBSBasic::InitService: 0.108 ms
19:43:15.567: ┣OBSBasic::InitPrimitives: 0.056 ms
19:43:15.567: ┗OBSBasic::Load: 11631.5 ms
19:43:15.567: =================================================
19:44:26.949: signal_handler_connect: signal 'removed' not found
