Laggy Stream + Inputlag feeling ingame
Itzi22
Hey guys, i need your help!
PC-Info:
- CPU: Ryzen 7800x3d
- GPU: RTX 4080
- RAM: DDR5 6000 CL32
- Monitor: LG OLED 240 Hz 1440p
OBS settings: (attached files)
Internet Connection: Down -> 64Mbts Upload -> ~30 Mbts DSL(Telekom)
I already tried a lot of settings but it doesnt really help. I just can feel lag/inputag while streaming - my aim seems to be less smooth (cant do micro adjustments like i usually do offstream)
If i watch my POV i see a lot of pixels on fast movements.
I dont know may it be my Internet?
Hopefully you can help me out!
File > Settings > Advanced > Sources > Enable Browser Source Hardware Acceleration, set this to unchecked fixes input lag when OBS is running. Anything else like Discord, Steam (Steam > settings > interface > disable bottom 4 sliders except last) or running Browsers should also have GPU/Hardware acceleration disabled for no input lag.
Make sure under Nvidia Control Panel > Manage 3D settings > add the OBS exe, and set the preferred refresh rate to Highest, otherwise OBS when running may be messing with your screen refresh rate. Disabling the OBS preview is also recommended.
You can also try disabling Multipass and Psychovisual Tuning, they both use cuda cores and eat into your GPU usage, if you're near 100% GPU usage those can cause extra bottlenecking. Otherwise the rest of those settings look fine. Make sure you're running OBS as Administrator if you don't have HAGS enabled in Windows.
I just wanna say you are the goat. I've been facing an issue for 3 years now where my FPS in game would show a steady 200-240 but it would feel blurry. It had the visual clarity and feel of 60fps, but didn't look as bad as if I literally locked my fps to 60. If that makes sense. The second I pressed record with any settings, my aim would feel just enough input lag that nothing ever felt crisp and precise. Everyone told me my settings were too high or my hardware was bottlenecking, but I had a 3070 and GPU never even went past 50-80% ever on my fps games.
Anyways long story short that you didn't ask for, I built a new PC thinking the much better hardware would fix the problem and it didn't. Very disappointed. But I saw this and switching the preferred refresh rate in OBS.exe to highest available and it fixed it. You have no idea how good it feels to finally get the smoothness of my 240hz while still recording.
You're a life saver bro.
Is there a way to do this for AMD GPUs?
Is there a fix like this for AMD?
Thanks for info ♥
Nvidia control panel has not the "add application" feature now days. but the Nvidia App does.
As well Nvidia App has not the feature to set the preferred refresh rate. Thus i set it in Global Settings.
