Media Controls
Media Controls 0.5.0
Not showing icons should only happen when your OBS version is not version 26 .0 or higher
my obs is 26.1.1, icons still not showing. (using material dark theme)
@schist99 do the icons show on the source toolbar with that theme? Because this plugins should use the same icons as used in the source toolbar. If they are also not shown there the icons should be added to the theme you are using.
Hey, your plugin is GREAT, but I have a little mess with thumbnail buttons. I have OBS (26.1.2), running it on OSX 10.14.6 (Mojave). Is there any way how to fix it? Thanks!
How do i remove this plugin? I installed it and when i dont want to run it in a dock it puts a huge gray rectangle over my stream preview.
Hi, thanks for the plugin, it's much better than the built in vlc controls. I was wondering if it would be possible to control multiple media sources with one control. I have two videos that are synced together in time and need to play them either side by side or individually but cutting back and forth between them quickly. While there are a couple work arounds I could use, it would be nice to just hit a single play button and have them both start simultaneously. Thanks, morris
If I want to use it on mac obs 25.0.8, should I install 0.2.2.pkg?
If so, where is the old version download link?
Thanks!
Thanks for great plugin! Is it possible to add a feature to controls which pauses after current media? I have a media playlist which loops and I would like to have "button" which pauses the media playlist playing after current media is finished.
Thanks!
how do i add 7 sec forward hotkeys like
Replay Source hotkey on setting
or
on stream deck i am noob to WebSocket
Hello !! beautiful plugin !!
can you add play-pause functionality like on vlc?
that is, when a track ends it pauses instead of immediately skipping to the next track
this helps a lot to change scene at the end of the tracks with precision without going over the next one
thank you
Sorry if its been asked or mentioned previously, but is it possible when using this plugin with VLC playlists, to also show the Filename which is queued up to be played?
to add onto that further would also be neat to have a 'selective media monitor' ability... since i have a half dozen sources on one scene which i dont want to monitor AT ALL while some i do..
ok.. got into actually testing it a bit more thorough and realizing only showing media sources which are 'visible' before i make the scene switch.
Follow if a media file visibility is toggled on/off?
I'm trying to set up OBS for a client- is there a way to have this plugin follow if a media file visibility is toggled on/off. Showing all media sources won't really work- looking at 100+ videos/stingers. I'm trying to keep him in one scene with a bunch of nested scenes- turn toggle source on it plays- then toggle off.
Working on MAC OS.
Thanks for the hard work!
