MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices
Free MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices 2.0.1.0
Just set up this with OBS and works well. I'm using an APC40 Mk1 which works fantastic.
Is there is a way I can setup LED feedback? For example if a source is toggled then pad lights stay on or off. I think I might have been missing something as I see if has been mentioned in the previous comment. So I am unsure how, if possible.
Only Launchpad & APC MINI are currently supported.
Could you write down here the exact name of your APC device, as it appear on devmgmt.msc , under the section "Sound, Video and game contollers" (case sensitive) ?
The name of the device is Akai APC40. Hope this helps.
Hey! I really love this app, it's so useful for OBS.
I was wondering if there was a way to choose the color of the keys of the launchpad.
Hello.
It's possible to assign two different messages to the same note?
Ex. Note On -Toggle Source Visibility On / Note Off -Toggle Source Visibility Off
Thank you.
Hello.
Thank you.
Yes.
Note ON is on "On Key Press" top part, while Note Off is on "On Key Release" bottom part, in the Keybind configuration window.
And you can assign as many actions as you want for the same event (Show some source, hide some others, mute, etc)
ciao ragazzi congratulazioni per questo utilissimo programma,
Ho un piccolo problema con il controllo slide.
Ho impostato lo slide ad esempio l'opacità, e quando vado ad usarlo se lo attivo è immediato, mentre quando vado a disattivarlo ci vogliono 3 secondi, è possibile ridurre questo lag?
Hi guys congratulations for this very useful program,
I have a little problem with the slide control.
I set the slide for example opacity, and when I go to use it if I activate it is immediate, while when I go to disable it takes 3 seconds, is it possible to reduce this lag?
On which filter are you experiencing this issue ?
MIDIControl 'only' forwards a signal to OBS, and should not add additional delay.
Hi there,
just tested the midi plugin. While having the midi editor open, I somehow pressed a button on my midi device and then OBS crashed (see attachment).
Best
Henning
Hello Etuldan,
Amazing program. I was using a custom python script a while back to map midi binds in obs. Needless to say it has been broken for a while. I found your controller and I am thrilled at the user friendly nature. I was hoping for a small request. Would you be able to add the option the "save replay" under the misc options? Thank you in advance.
Hi there,
Best
Henning
Do you have the lastest version of OBS with latest version of OBS Websocket plugin ?
hi Etuldan, thanks for your reply.
I'm seeing it on the opacity filter. example, imposed on obs midicontrol:
-Select the slider, On Slider Change -> Adjust filter -> color correction -> opacity.
when I raise the slide the command is immediate, when I lower it, it takes 5/6 seconds before it deactivates.
Hello! I am having a problem with the newest version. I am using TouchOSC and a tablet as my midi device. I can start the new version of Midi Control, but when I press a button on my midi controller, the program crashes and quits. This does not happen with older versions. Is there anything I can send you to help you with this issue? Thanks!
