Mixery
Mixery 2.0.1
derMiepz
Member
eZ_KrieG3R submitted a new resource:
Mixery - A Mixer inspired OBS theme to fit the v23 integration docks
About:
This is a very modified version of the "Dark" theme shipped with OBS. It contains code snippets from the themes "Acri" made by @Warchamp7 and "Rachni" made by @Fenrir. Those themes are also shipped with OBS. This theme is mainly meant for OBS v23 and higher but should work with earlier versions too.
There are two different versions. One with a custom font and one without.
Version with font:
hello, the media control plugin buttons are not appearing. I hope this can be fixed because I like this theme a lot :) Tnx
I just updated the theme. Please let me know if your issue is fixed.
at first it appeared fixed, but when I switched scenes the icons disappeared for media controls only. I have removed and reinstalled a new copy of the Mixery (with font), restarted OBS and everything, but it persist
If I switch themes it would be there initially, but when I switch scenes, it would be gone
