obs crashing popup after update
it says now at start the following obs plugins failed to load sl-browser-plugin
OBS isn't the problem.
Make sure all the plugins you installed are updated and are compatible with the OBS version you're using. If it isn't updated, do not update OBS or remove the plugin before updating OBS.
did you look at my crash logs to see what happened
