P P_JI_Ioxa New Member Sep 16, 2015 #1 OBS MP + Avermedia live gamer HD lite (Encoder AverMedia H.264(c985)), streams started 0 bitrate
P P_JI_Ioxa New Member Sep 16, 2015 #3 Harold said: Obs log missing Click to expand... Attachments 2015-09-16 23-44-46.txt 2015-09-16 23-44-46.txt 7.8 KB · Views: 79
L Lain Forum Admin Lain Forum Moderator Developer Sep 17, 2015 #4 I don't recommend using the C985's encoder for streaming. But I'm guessing that the device is active already, which may prevent it from working.
P P_JI_Ioxa New Member Sep 17, 2015 #5 Jim said: I don't recommend using the C985's encoder for streaming. But I'm guessing that the device is active already, which may prevent it from working. Click to expand... If you do not recommend to use the encoder c985, then why are you trying to combine AverMedia with their software
Harold Active Member Sep 17, 2015 #6 Because, for local recording, any encoder is fine since you can throw enough bitrate at them to offset their quality limitations.
