OBS not showing input after multiple tries
bccmkke
Hi all, so we use OBS for live streaming on Sundays at our church, it's connected to a ATEM Mini and a separate HDMI-USB switcher for lyrics green screen.
We set up the laptop, ATEM, cameras etc and pack them down weekly because it's a co-sharing space.
Most of the time it functions properly but sometimes the input that's connected to the ATEM is not showing on the OBS but it shows on a separate monitor, which is probably not an ATEM problem since the ATEM software controller is able to detect a connection?
Even with multiple times of re-plugging the ATEM in and out, OBS software restarted, the input still wouldn't go through and the capture device on OBS is not showing anything.
If you refer to the YouTube link attached below, you will see that nearing the end of the video, it miraculously functions as usual, only after many many tries.
https://youtu.be/llHLxE3p9q8
I'm just wondering is it normal for OBS to act that way with ATEM? Or does it has anything to do with the 6-year-old ATEM Mini being plugged in and out weekly? Thank you.
P/s: Attached images are the software versions (latest at the time of the video recording) and laptop's system information.
