OBS Preview Keeps Freezing
NostalgiaTripUK
Hey everybody, I'm currently tearing my hair out trying to resolve an issue I'm having with OBS where the preview keeps freezing. It mostly seems to occur when switching scenes or toggling game capture. I have tried;
  • Running as admin
  • Disabling HAGS
  • Tried StreamLabs OBS instead which showed similar problems (but there the whole application froze as well).
  • Updating GPU drivers
  • Re-installing OBS
I worry that it my GPU is at fault; the only weird thing there though is that the stream itself still works and any changes I make will show on the livestream even though I cannot see them take effect on OBS, and if I open studio mode the studio preview still works too. The studio preview likes to freeze too but that one seems to fix itself if I disable/enable studio mode again, this fix does not work when disabling/enabling preview.
Any help would be greatly appreciated, log attached!
Also tried running OBS in safe mode, same issue still occuring. Uploaded my logs to the OBS analyzer and fixed any issues that were occuring, still no luck.
I'm having the same problem. I've read the quick help tips, reinstalled my NVIDIA drivers, forced the executable to run in Admin mode, used software encoding instead of NVENC, etc. and my preview continues to freeze and break for no reason. I'm not even streaming; just recording footage for myself.
I had to reinstall Windows for other reasons, so I'm using Windows 11 24H2. I don't recall this happening to me on 23H2, but I can't say this for certain. Either way, I'm hoping for someone to tell me what the problem is.
I had also encounter the same issue in OBS Studio on Windows 11 24H2, where the previews (oddly, with the exception of multiview) would freezes if I switch between it and the games (specifically games that utilize Unreal Engine 4 and 5) by either alt-tabbing or minimize the games.
I tried reinstalling GPU driver and switching to software encoding, but the issue still persists. I think it's definitely have something to do with Windows 11 24H2.
Update (November 6, 2024): I think I found the possible cause of the issue, and possibility also Nvidia-related (as they recently updated the VRR algorithm in their driver).
It turns out that enable G-Sync under Windows 11 24H2 can cause the preview window to be freezes when switching between games and OBS Studio. Once G-Sync, or any VRR tech like FreeSync, is disabled, the issue goes away.
For the time being, I would advices you guys to disable VRR while streaming.
Yup looks like this is the fix, wish I saw this before I ended my livestream tonight for a proper test! I've just played around with OBS trying all the usual triggers over the last 10 minutes and not had a single issue. I'll be able to get a more thorough test completed when I next livestream and will report back to confirm if it held up.
Yeah, the workaround helped since I have a 1440p 180Hz FreeSync monitor. Now the preview no longer freezes when switching apps now.
Hopefully, this gets fixed in the next NVIDIA driver update so I won't have to turn off VRR just to use OBS.
I can confirm the previous comments - disabling G-Sync/Freesync fixes the issue. Looks like we need to create Nvidia report, because it looks like it's Nvidia's driver problem.
I confirm. RX 6800XT, Ryzen 5700X and OBS preview freezing and turn FreeSync off resolve problem. For information - Tiktok Live Studio has the same problem and the same solution. This is again Windows problem not GPU drivers.
BTW. i reinstall Windows few days ago after replacing a SSD to KC3000. Fresh install and problem persist.
To fix without turning off g-sync globally, this worked for me: go to NVIDIA Control Panel, under 3D Settings > Manage 3D Settings > Program Settings, select OBS Studio (bin/64bit/obs64.exe), scroll down to Vertical Sync, set it to "Off," then hit Apply.
If there is any way to make this thread a bit more noticeable, that'd be fantastic, because this is a problem I've had for a few days and it took ages to find the solution. Thank you @Yuuyatails!
Seems like it's another workaround.
Also, there should be a similar setting for AMD Radeon users, since this issue also affects AMD Radeon users as well.
Hello, for me, disabling these two settings in Windows 11 worked.
Go to: Settings -> System -> Display -> Graphics -> Advanced graphics settings, and turn off these two settings: Hardware-accelerated GPU scheduling and Variable refresh rate
Also, you can try disabling them one by one.
Thanks for the suggestion, this appears to be working for me so far.
How do I do this? I'm not too clever with computers sorry
This did it for me! Setting up a new Windows 11 computer after streaming on Windows 10 for so long and the freezing preview was driving me wild! Checked my GPU settings (Radeon) and Freesync was disabled, but VRR was turned on in Windows. Turned it off and that was that.
I'm trying to do this but it won't let me scroll to find Vertical Sync, and everything is grayed out. Is there a setting to fix this? I tried resetting my Drs Nvidia Corporation folder but that didn't work. Thanks!
That's odd. Normally, it will allow you to scroll down via either the scroll wheel on the mouse or the scroll bar on the right edge of the menu.
It should be noted that Nvidia is currently phasing out the Nvidia Control Panel in favor of the Nvidia App.
In the Nvidia app, go to the 'Graphics' tab, select OBS Studio in the list of programs in the 'Program Settings' tab, and look for 'Vertical Sync' setting, and set it to 'Off'.
