OBS showing in task manager, but not showing up in taskbar
Deadman
So I've been having this issue for a while, last night I decided to uninstall the program and reinstall it, it worked and opened after the install, I recorded and everything went fine. Today when I tried opening OBS it shows up in task manager that its running but it doesn't show up at all, its not on a different monitor, I've looked in the system tray, I've looked at old post similar or exactly like this, but I can't find a solution. Not sure whats going on, let me know if you guys/gals have any ideas! There's a photo of both my monitor, with task manager and the system tray open, not sure if that helps!
