Overstream.Studio | Animated widgets for sport streams
Hi!
Thanks for your suggestion, I'll think about it. If you have any visual examples how this might look like, please send it to me.
Thank you!
Hi robotrobik, excellent job!
It would be really interesting to add a way to announce replacements.
For example in the list of players, choose which players enter and which players leave.
Hi!
Thank you!
I'll think of a "graphical" way to present and configure this and let you know.
Anyway, I recently started a football game broadcast project, I'm Portuguese and I need an app like yours, I have to do some tests but I'm able to have several ideas for you and suggestions to improve the way users like me can "work" better.
Anyway, despite not using your project yet, since January I've been an active member of your Patreon project and I'm very happy with all the development it's had so far.
I will better structure my idea for player substitutions and present it to you to analyze and validate if it is possible to implement it.
Regarding the other situations, I will also make an overview and then show you what you could improve, so that we users can make better use of it.
Thanks a lot, your suggestions would be very valuable to me.
Hello again,
can I change the score only via attributes? Would it not be easier to have a +/- function next to the timer under events?
Yes, indeed the last update was a bit complicated. In short, you need to create match attributes and add there an attribute of "Score" type. Then assign this attributes in the Match settings. I'll try to prepare detailed how-to asap, actually there is simple logic
Can you explain this step by step please...it hurts to be not able to change the score value only the timer is running
Hello, I have a question regarding the timer. It feels like it runs slowly than actual time or get stuck at somepoint, have you had this experience yet?
No, I haven't noticed, but this can happen. How many CPU cores and how much RAM do you have on the computer you use for streaming? At times when the processor may be overloaded with other tasks, the environment in which this overstream.studio program is running can get block and this leads to timer delays. I think this can be observed in the Windows System Monitor. At times of delay, the percentage of CPU usage can reach 100% or something similar
I do wonder, hopefully I'll receive an answer, because it's not been updated for an awful lot of time, is this app dead? I am a Patreon subscriber and this app helped me immensely at many times, that's why I'm curious.
Hello!
Indeed, there have been no updates for a long time. But no, it is not dead. I have some plans for an update, but due to another project, I do not have enough time to test everything properly.
Hi, I want to ask this
So I just created data directory, and then after I created the widget, I can import the data there. So it just become an empty widget. Is there any tutorial for this?
Cause from what I see on the youtube video, there's a button that make you can choose what data you want to put.
I think I figured out what the problem is. You are using the Starting Line Up widget with an event of the Individual Competition type. But this widget can only be used with an event of the Match type. For Individual Competitions, there is a similar widget called Starting List.
1. Create a Bundle with widgets that you will use in your Event
2. Add the Starting List widget there
3. Add this Bundle to the event
4. In the event settings, select this widget as Starting List
  • 2024-11-05 01_02_36-Starting List _ 8c97921a-149c-49e0-881b-789a4e341c25 — Mozilla Firefox.png
I tried multiple time the starting lineup widget but i only see an empty color animation without team players. What do i wrong? I have read the documentation and thistopic but nothing helped.
