Packet loss in game and bitrate drops to zero when streaming Fortnite.
benwnl
I have had this problem for about a year now. I am able to stream any other game just fine with a bitrate of 6k. My internet speeds are good (150mpbs up/down). It's only when I try and stream fortnite my bitrate drops to zero, and I get 60% packet loss in game. I've tried running OBS as admin, turning off gpu hardware-accel. scheduling, lowering the bitrate as low as 500 kbs, changing stream quality, lowering my stream to 30fps, uninstalling the game and resetting it to default settings.
It's not a hardware problem as my specs are pretty good:
i7-10750H
2070 Super Max Q
16GB Ram
I am unable to give you the log file because the stream crashes and then OBS reads that it "failed to get a response from the server", so retrieving the log file is not possible.
The red areas in the image that I attached below are when I start streaming Fortnite.
Any help is greatly appreciated.
