Shadertastic
Shadertastic 1.3.1
Perhaps this is related?
I see, somehow the UI is not rendered. This is actually quite weird, since it's not directly related to OBS (for the techies: why would Qt do that ? )
I'll ask friends of mine who have a Mac and see if I can find a solution...
You are awesome! However, it does work in filters and scene transitions. Thank you!
I am having a similar issue with Vignetter .lua by the Geek Squad. It wasn't working then somebody posted a fix. Not sure if it was them or not. You could use all the functions, but when you selected it the function you had chosen was not appearing when you would select it in filters, but now when you select it in sources it works. Actually, for the first time I can see the name of what I had chosen. It might be the update 33. RC1 or I wonder if stream up had something to do with it, but probably not Stream up. It's nice though that it is finally working....update: When I click on filters in the left column the preset is their, but when I right click on the source and choose filters it doesn't work properly. Weird,
Apparently it happens on Mac OS 13.7.8, so I would not bet on this at this point.
@Want To Learn do you have any other plugin that has a setting dialog, but working? So I can check how it handles things. Maybe I forgot something
Hm...I'll check. Thanks. It appears Zoominator does and some others to. I find it in tools.
Mr xurei, Don't even worry about it fully loading in tools like the above pic. It really does everything after you find it in filters for the source then adjust it in properties. It also works in scene transitions to. You Rock! Thanks.
