Should be possible.Is it possible to use the second nic on a pc to directly connect to second pc to stream to? I ask because don't have ethernet connection to second pc from router but do have a second nic on gaming pc
You could split up all of your audio sources in OBS and assign them to different channels. Then on the second system, you could turn off what you don't want to hear. You can get on YouTube and learn how to separate the different audio channels. Hope this helps.So when I add a teleport on the second pc it adds teleport audio to all my scenes but some of my scenes I don't want the audio from teleport. If I mute it in one scene it mutes it in all my scenes, how do I get around this?
If there was no significant lag on the network it should not happen. If you are checking via audio monitoring, check your recording or stream. Audio monitoring in my experience is not always right.Hello, I just set this up. It's a brilliant plug-in, but I have an issue. After like 20 minutes audio goes completely out of sync. I'm using a no name 1G switch with default quality setting at 90. Would a 10g switch help? Source is in 4K 120 fps. Thanks.
- Teleport now uses TurboJPEG v3 API instead of libjpeg API.
- Fix a bug that may have lead to more memory being used than necessary.
- Add a warning that when Teleport output is active, that output settings in OBS cannot be changed.
only for x86. See https://github.com/fzwoch/obs-teleport/issues/43Do you have a working version of obs teleport for macOS sonoma?
The teleport source is correctly listed, it just doesn't display anythingDoes discovery fail or transmitting? Discovery uses multicast. I have no idea if Windows firewall allows that? I have no idea what it does and what not..
Then perhaps you need to punch a hole in the FW and set a static port for the Teleport output. Or someones actually knows what Windows FW is actually doing..The teleport source is correctly listed, it just doesn't display anything
Nevemind fixed by installing NDI 5 Runtime :DHello, i got error message "Status_wait_2" and when i click ok obs crached
OBS 30.0.0
Teleport 0.7.0
log file:
21:46:36.389: [Safe Mode] Unclean shutdown detected!
21:46:40.446: [Safe Mode] User elected to launch normally.
21:46:40.447: CPU Name: 13th Gen Intel(R) Core(TM) i7-13700K
21:46:40.447: CPU Speed: 3418MHz
21:46:40.447: Physical Cores: 16, Logical Cores: 24
21:46:40.447: Physical Memory: 65300MB Total, 48393MB Free
21:46:40.447: Windows Version: 10.0 Build 22631 (release: 23H2; revision: 3007; 64-bit)
21:46:40.447: Running as administrator: true
21:46:40.447: Windows 10/11 Gaming Features:
21:46:40.447: Game Bar: On
21:46:40.447: Game DVR: On
21:46:40.447: Game DVR Background Recording: Off
21:46:40.448: Game Mode: Probably On (no reg key set)
21:46:40.449: Sec. Software Status:
21:46:40.450: Microsoft Defender Antivirus: enabled (AV)
21:46:40.450: Windows Firewall: enabled (FW)
21:46:40.451: Current Date/Time: 2024-01-24, 21:46:40
21:46:40.451: Browser Hardware Acceleration: true
21:46:40.451: Hide OBS windows from screen capture: false
21:46:40.451: Qt Version: 6.5.3 (runtime), 6.5.3 (compiled)
21:46:40.451: Portable mode: false
21:46:40.535: OBS 30.0.0 (64-bit, windows)
21:46:40.535: ---------------------------------
21:46:40.536: ---------------------------------
21:46:40.536: audio settings reset:
21:46:40.536: samples per sec: 48000
21:46:40.536: speakers: 2
21:46:40.536: max buffering: 960 milliseconds
21:46:40.536: buffering type: dynamically increasing
21:46:40.537: ---------------------------------
21:46:40.537: Initializing D3D11...
21:46:40.537: Available Video Adapters:
21:46:40.546: Adapter 0: NVIDIA GeForce RTX 3090
21:46:40.546: Dedicated VRAM: 25522339840 (23.8 GiB)
21:46:40.546: Shared VRAM: 34236358656 (31.9 GiB)
21:46:40.546: PCI ID: 10de:2204
21:46:40.546: HAGS Status: Enabled (Default: No, Driver status: Supported)
21:46:40.546: Driver Version: 31.0.15.4633
21:46:40.546: output 0:
21:46:40.546: name=C27HG7x
21:46:40.546: pos={0, 0}
21:46:40.546: size={2560, 1440}
21:46:40.546: attached=true
21:46:40.546: refresh=144
21:46:40.546: bits_per_color=8
21:46:40.546: space=RGB_FULL_G22_NONE_P709
21:46:40.546: sdr_white_nits=80
21:46:40.546: nit_range=[min=0.010000, max=240.000000, max_full_frame=240.000000]
21:46:40.546: dpi=96 (100%)
21:46:40.546: id=\\?\DISPLAY#SAM0E16#5&cb01776&0&UID4357#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
21:46:40.546: alt_id=\\.\DISPLAY1
21:46:40.548: Loading up D3D11 on adapter NVIDIA GeForce RTX 3090 (0)
21:46:40.632: D3D11 loaded successfully, feature level used: b000
21:46:40.632: DXGI increase maximum frame latency success
21:46:40.632: Hardware-Accelerated GPU Scheduling enabled on adapter!
21:46:40.633: D3D11 GPU priority setup success
21:46:40.787: ---------------------------------
21:46:40.787: video settings reset:
21:46:40.787: base resolution: 2560x1440
21:46:40.787: output resolution: 1920x1080
21:46:40.787: downscale filter: Lanczos
21:46:40.787: fps: 60/1
21:46:40.787: format: NV12
21:46:40.787: YUV mode: Rec. 709/Full
21:46:40.787: NV12 texture support enabled
21:46:40.787: P010 texture support not available
21:46:40.788: Audio monitoring device:
21:46:40.788: name: Output 1/2 (Komplete Audio 6 MK2)
21:46:40.788: id: {0.0.0.00000000}.{daae8a16-c8e6-4f2b-a66b-66054006b373}
21:46:40.788: ---------------------------------
21:46:40.790: No AJA devices found, skipping loading AJA UI plugin
21:46:40.790: Failed to initialize module 'aja-output-ui.dll'
21:46:40.791: No AJA devices found, skipping loading AJA plugin
21:46:40.791: Failed to initialize module 'aja.dll'
21:46:40.792: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
21:46:40.794: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
21:46:40.794: Failed to load 'en-US' text for module: 'decklink-captions.dll'
21:46:40.795: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
21:46:40.804: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
21:46:40.804: Failed to initialize module 'decklink.dll'
21:46:40.819: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
21:46:40.819: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
21:46:40.820: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
21:46:40.831: [obs-browser]: Version 2.22.1
21:46:40.831: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2594+gc69ad37+chromium-103.0.5060.134 (compiled)
21:46:40.835: NVENC supported
21:46:41.493: [NVENC] AV1 is not supported
21:46:41.494: [noise suppress]: NVIDIA denoiser disabled, redistributable not found or could not be loaded.
21:46:41.495: Failed to get NVVideoEffects.dll version info size
21:46:41.495: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
21:46:41.540: [obs-teleport] version: 0.7.0
21:46:41.545: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.3.3 | RPC Version: 1)
21:46:41.545: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.5.3 | Qt version (run-time): 6.5.3
21:46:41.545: [obs-websocket] [obs_module_load] Linked ASIO Version: 102800
21:46:41.558: [obs-websocket] [obs_module_load] Module loaded.
21:46:41.561: [rtmp-services plugin] Remote update of URL "https://obsproject.com/obs2_update/rtmp-services/v5/package.json" failed: getaddrinfo() thread failed to start
21:46:41.563: [vlc-video]: VLC 3.0.20 Vetinari found, VLC video source enabled
21:46:41.565: [win-capture plugin] Remote update of URL "https://obsproject.com/obs2_update/win-capture/v1/package.json" failed: getaddrinfo() thread failed to start
21:46:41.570: ---------------------------------
21:46:41.570: Loaded Modules:
21:46:41.570: win-wasapi.dll
21:46:41.570: win-dshow.dll
21:46:41.570: win-capture.dll
21:46:41.570: vlc-video.dll
21:46:41.570: text-freetype2.dll
21:46:41.570: rtmp-services.dll
21:46:41.570: obs-x264.dll
21:46:41.570: obs-websocket.dll
21:46:41.570: obs-webrtc.dll
21:46:41.570: obs-vst.dll
21:46:41.570: obs-transitions.dll
21:46:41.570: obs-text.dll
21:46:41.570: obs-teleport.dll
21:46:41.570: obs-qsv11.dll
21:46:41.570: obs-outputs.dll
21:46:41.570: obs-filters.dll
21:46:41.570: obs-ffmpeg.dll
21:46:41.570: obs-browser.dll
21:46:41.570: image-source.dll
21:46:41.570: frontend-tools.dll
21:46:41.570: decklink-output-ui.dll
21:46:41.570: decklink-captions.dll
21:46:41.570: coreaudio-encoder.dll
21:46:41.570: QWidget::setTabOrder: 'first' and 'second' must be in the same window
21:46:41.570: ==== Startup complete ===============================================
21:46:41.646: All scene data cleared
21:46:41.646: ------------------------------------------------
21:46:41.653: [win-wasapi: 'Desktop Audio'] update settings:
21:46:41.653: device id: {0.0.0.00000000}.{daae8a16-c8e6-4f2b-a66b-66054006b373}
21:46:41.653: use device timing: 1
21:46:41.655: [Loaded global audio device]: 'Desktop Audio'
21:46:41.656: [win-wasapi: 'Mic/Aux'] update settings:
21:46:41.656: device id: default
21:46:41.656: use device timing: 0
21:46:41.657: [Loaded global audio device]: 'Mic/Aux'
21:46:41.659: [duplicator-monitor-capture: 'Display Capture'] update settings:
21:46:41.659: display: C27HG7x (2560x1440)
21:46:41.659: cursor: false
21:46:41.659: method: DXGI
21:46:41.659: id: \\?\DISPLAY#SAM0E16#5&cb01776&0&UID4357#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
21:46:41.659: alt_id: \\.\DISPLAY1
21:46:41.659: setting_id: \\?\DISPLAY#SAM0E16#5&cb01776&0&UID4357#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
21:46:41.659: force SDR: false
21:46:41.663: Switched to scene 'Scene'
21:46:41.663: ------------------------------------------------
21:46:41.663: Loaded scenes:
21:46:41.663: - scene 'Scene':
21:46:41.663: - source: 'Desktop Audio' (wasapi_output_capture)
21:46:41.663: - source: 'Display Capture' (monitor_capture)
21:46:41.668: WASAPI: Device 'Output 1/2 (Komplete Audio 6 MK2)' [44100 Hz] initialized (source: Desktop Audio)
21:46:41.671: WASAPI: Device 'Microphone (Wireless Stereo Headset)' [16000 Hz] initialized (source: Mic/Aux)
21:46:41.857: WhatsNewInfoThread::run: Failed to fetch whatsnew file: getaddrinfo() thread failed to start
That seems to be the OBS update checker. Unrelated to Teleport.Hello, i got error message "Status_wait_2" and when i click ok obs crached
OBS 30.0.0
Teleport 0.7.0
log file:
For anybody else with this issue: I needed to add an inbound rule for the specific port used on the gaming PC
