Question / Help The window capture is not working with OBS 23.1.0. (Win10 64 bit)
JuEs
The function of Window Capture does not detect Skype and Chrome, and it only shows a black window or a small white bar at the top, but Window Capture does work with Mozilla Firefox and other windows. What could be problem? I re-installed OBS, and re-started the computer and nothing worked. By the way, NDI is active in Skype. Strangely enough, I can detect Skype and Chrome if I select Display Capture.
I hope somebody can help me or has the answer to this problem
You need to disable hardware acceleration in those apps if you wish to capture them with window capture.
Skype does not have the hardware acceleration, and my computer does not have hardware acceleration option in my display settings, On the other hand, I turn off hardware acceleration on Chrome, and it works!
