I've just spent 4 hours trying to fix whatever is going on but, the same settings work in every other game I've tested and streamed up to now.
The problem: OBS hangs and freezes the recording and stream randomly when trying to play STAR WARS Jedi: Survivor.
The System:
Thank you for your time! Hope we can get to the bottom of this.
The System:
- Windows 11 build: 22621.1485
- Nvidia driver: 531.68
- OBS: 29.0.2
- RAM: 32GB DDR4 3000Mhz
- GPU: 3080 ti 12GB
- CPU: AMD Ryzen 7 5800x3d
- Recording Format: mkv
- Encoder: NVIDIA NVENC HEVC
- Resolution: 1440p
- Rate Control: VBR 10'000-15'000Kbps
- Keyframe Interval: 0
- Preset: P4
- Tuning: High Quality
- Multipass Mode: Two Passes
- Profile: main10
- Psycho Visual Tuning: On
- Max B-frames: 2
- Resolution: 1080p
- Rate Control: CBR 10'000Kbps
- Preset: P3
- Profile: main10
- Max B-frames: 2
