TwitchTest Quality 0 and I have bad bitrate in the evening
realmode
Quality 0 in twitchtest, and I have bad bitrate in the evening only. In the morning bitrate is good, but quality is still 0. Also did some tests in PingPlotter and TwitchTest. You can see that quality in TwitchTest is not 0 but yesterday it was 0 all day and previous days as well (something fixed today?). What can I do to fix this?
You need to contact your ISP for the broken service they are giving to you.
The Twitch test verifies the quality of the connection against Twitch servers. They need to figure out what is broken.
so I need to call them and what I need to say? Like 'I have packet losses and you need to fix it' or what?
The SMTP protocol isn't working properly in their network and you can't stream to twitch.
If you need to explain them you did several tests of this protocol used for streaming and shows non or incredible bad quality results against twitch servers. This is normally due to bad configuration or fault hardware on the ISP network.
Thank you!
