Video Output is Currently Active - teleport keeps crashing
asaudio
Hey everyone, I need some help.
My OBS is telling me that i have my video output active, and i can't change my video settings. Keep in mind I don't have virtual cam enabled and everytime I try turning off teleport, my OBS crashes. No NDI plugins either.
I'd really appreciate some help, I'm stressed from this.
  • Untitled document - Google Docs.pdf
Do you have the Aitum Vertical plugin? If so, uncheck the "Backtrack always on" box. That will disable the Backtrack feature. You could still record and stream using your vertical scenes, though. Check the box again if you want to resume making shorts.
This worked for me
That's exactly what I had turned on. Thank you very much.
