When I alt+tab from cs:go my obs instantly crashing
eugenexeu
I start streamimg cs:go and when I try to alt+tab its instanly crash. My preview in obs just lag and bitrate get down from 6000 to 0 immediately. PC start laging too, but when i close obs everything is go normal. If i just play and do not use alt+tab stream go normal. Can some one help me please. I use last version of obs 27.2.3. I reinstall obs but nothing. I try to use previous version and problem steal the same. In crashe folder nothing.
Last log: https://obsproject.com/logs/Xx03Mj6IK4lEcyH6
Try this in Windows:
Settings > System > Display > Graphics > Click the text "Change default graphics settings" and UNCHECK it. Reboot PC and see if it helps.
