MacOS support
I was able to get it semi-working on OSX. I am going to put this here just in case it helps someone else.
1. The URL for the source and control panel should have no spaces in it. It appears to URL encode it, so if you have spaces, it will garble your URL, which won't be read by the browser.
2.Use"file:///" protocol to load the control panel
3. It appears you can use the normal dialog for loading the Browser source. Choose "Local file".
4. Logos still show up broken - The dialogue works properly when you load the image, but then it appears it isn't referenced properly so it shows that "broken" image that chrome shows you when your images have an address, but can't find the file.
As you can see, the panel works, but shows the images not being found. I am new to the plugin, so I don't know what other features work, but my guess is that the broken image on MacOS is due to how it is referencing the file. I haven't dug into the code at this point.
This might already be known, but maybe this helps someone else. Love it.
When you click on the logo, you see this (after you attempted to load it).
Then when you go to the dialoge, it will allow you to pull in the image, but it breaks agan.
I was thinking I might be able to hard code the images, but again, I didn't dive too deeply into it.
This is OBS 27.1.3 with Chrome Version 96.0.4664.55 (Official Build) (x86_64)
