@m0gwai try using this video and install it in the order in the video it worked for me. not sure if it will work for the mac but you can try
@m0gwai apologies https://www.youtube.com/watch?v=EN_nmwc3bHY&t=789sThanks but I think you missed the link? :)
Did u find solution? I have the same problem...Hey all, so I just discovered lower thirds. I've installed it but having a hard time understanding how to use the memory slots.
Every time I create a new memory slot, it overwrites what I inputted on the first memory slot . In addition, when I click any memory slot to edit, it will re write the memory to what I initially written in it.
Can anyone help with instructions on how to use?
press and hold an existing memory slot to clear it and then you can write something new and next time you click it, that memory slot will get reassigned.Did u find solution? I have the same problem...
<style>
@import url('file:///Users/plex/Downloads/Griffinize-oxOV.ttf');
</style>
Did either of you have any luck with a LOCAL font though?I came here to find that out too, and now realise there is a Custom Font section in the global settings:
