Audio Monitor
Audio Monitor 0.10.1
Just a suggestion, can you add a "dock" audio monitor function for the number 1 Googled- free tts auto chat for streamers
(not posting website since the spam detection system is overly sensitive about it)
The new free tts auto chat readers are making you go thru the obs dock system....
so i can hear the reader without overloading my system, crashing my stream by keeping a web browser open.
I prefer to keep web browser in low memory mode.(web browser sources)
Hi there - not sure if this is the support channel, but here goes: We've been using the Audio Monitor filter for 5 years now without a hitch, directing a video's audio source to a separate digital OUTPUT device in our Win10 machine. Our primary OBS INPUT used to be from a mix off our house sound system via a USB audio interface (actually a Zoom H6). Everything was working fine. However, we recently replaced our aging house mixer with a spanking new Allen&Heath Qu-5, and now our primary INPUT to OBS is directly via USB (current ASIO Windows drivers). Now, though, all the main stream audio output is also going to out via that same USB back into the house as well as the newly re-configured Audio Monitor output - so, we're getting the main stream audio back into the house even if the Audio Monitor filter isn't on a source. Is this expected behaviour? Do I need to start understanding Tracks, so I can still treat the USB OUTPUT to the Qu-5 separately from the main stream output?
Hi! Unfortunately, the amazing Audio Monitor plugin stopped working with OBS 32.0.0-beta2 (Mac). Hopefully this can be fixed soon. Thanks a lot for your great work!
OBS Log:
23:58:48.581: os_dlopen(/Users/$USERNAME/Library/Application Support/obs-studio/plugins/audio-monitor.plugin/Contents/MacOS/audio-monitor->/Users/$USERNAME/Library/Application Support/obs-studio/plugins/audio-monitor.plugin/Contents/MacOS/audio-monitor): dlopen(/Users/$USERNAME/Library/Application Support/obs-studio/plugins/audio-monitor.plugin/Contents/MacOS/audio-monitor, 0x0106): Symbol not found: _obs_frontend_add_dock
23:58:48.581: Referenced from: <B8CCB420-6C24-3BB6-BCA3-13A6B70A457E> /Users/$USERNAME/Library/Application Support/obs-studio/plugins/audio-monitor.plugin/Contents/MacOS/audio-monitor
23:58:48.581: Expected in: <1FB7E207-BF2F-340F-9671-F3F2C13B4CE2> /Applications/OBS.app/Contents/Frameworks/obs-frontend-api.dylib
23:58:48.581:
23:58:48.581: Module '/Users/$USERNAME/Library/Application Support/obs-studio/plugins/audio-monitor.plugin/Contents/MacOS/audio-monitor' not loaded
@Jazzcrack it looks like your OBS is trying to load an old version of audio monitor. In version 0.10.0 obs_frontend_add_dock was removed, but the error indicates it still is trying to use it
@Exeldro Thanks so much for the quick reply and pointing me in the right direction! You nailed it—it was indeed an old version of the Audio Monitor plugin lingering around. I mistakenly assumed the new version would just overwrite the old one during installation. My bad! I’ve updated it properly now, and everything is running smoothly again.
Really appreciate your help and the awesome work you’re doing with this plugin. Keep it up, and thanks a million!
The plugins don't show to remove it.
Okay I found it. Done it by opening OBS and clicking show settings folder. Shows the exact same location, but actually shows the files I was searching for. So strange. Now working. Now just to fix all the other ones that don't work since jobs 32 update.
Hi there! Excited to utilize this plugin but I can't seem to get it working. The data and DLLs are in the correct place.
I've downloaded the latest version of the plugin (0.10.0) for Windows, and I'm using OBS 31.0.1 as I understand version 32+ isn't compatible with the plugin yet.
When I go to add a Filter to any audio source, the plugin doesn't show up. Not sure if I'm missing something, or if there's a compatibility issue. Thanks!
@w4tchmaker version 0.10.0 requires OBS 31.1.0 or higher. I f want it on OBS 31.0.1 you need an older version. OBS 32 should work fine with version 0.10.0 of the plugin
Thank you so much for the quick reply!
Good news, OBS now sees the plugin and I can add it! However, I can't seem to get the routing right.
My goal is for all "Desktop Audio" to route through my mic interface so that web apps (Zencastr, Google Meet) will hear desktop audio as part of the microphone input.
When I set this up as such (below) and the Monitor volume is at 100%, I get a terrible feedback loop - so I *think* the signal is coming through. When I reduce this down to 50% or 70% everything sounds clean again.
However, the desktop audio (which is registering in OBS) does not get "heard" by the web apps at all. I do not see or hear any signal coming through the interface from the Desktop source.
I'm sure I'm missing something here!
One other thought- my Focusrite interface has 4 inputs but I'm only using 1 for the mic. I'm wondering if there's something I'd need to config in the Focsurite software in order for the Filter to route through the "correct" input?
I ticked the "mono" box in the Filter here, but that didn't seem to affect anything.
I run a setup where it would be useful to have particular monitoring paths in my setup which spans a total of five PCs, two of which handle the vast bulk of the audio I would monitor the most.
In order to monitor the main loop, it would be enormously helpful to have a so-called "mix-minus" setup, whereby I can monitor the mix, minus (see what I did there?) my microphone so I don't confuse myself by hearing my own speech, likely with some manner of delay. I realize I could set up one of OBS Studio's built-in channels to catch all channels, then turn off just my microphone on that channel, but this wouldn't necessarily work for other users' workflow as they may need that extra channel. The functionality may be there but I might be missing what it may to make that work without involving OBS Studio's built-in channels to facilitate this.
Thoughts?
--Katt. =^.^=
Is it currently possible to add more than 6 Tracks to this plugin? If not, would it be possible to add an option to add more Tracks?
If you are talking about the checkbox for each channel, this is an OBS Studio limitation, not a plugin limitation. You would have to make changes to OBS Studio itself to get this support.
--Katt. =^.^=
Hello, I tried to install Audio Monitor 0.10.0 on MacOS Sequoia 15.7.1 – I know how to bypass the security restrictions and get the installer to run – 1) possibilities are limited - it is only possible to install it on my personal account – I cannot identify a specific user location 2) I cannot determine where the new plugin file was saved after installation – the old file is still in the expected location and has not been replaced by the new one. Do you have any tips on how I can still update Audio Monitor and thus also update to OBS 32.x.x?
