Scoreboard Overlay and Controller Plugin
Free Scoreboard Overlay and Controller Plugin 5.0.1
Thank you for creating this. I'm using Windows 11 and installed this today using the .exe file. Unfortunately I don't see the scoreboard appear on my screen when I add it as a source to a scene. Is there something I need to do on the server end regarding a firewall that I'm missing? Also, the file folder containing the .json plugin doesn't contain an HTML file. Is that maybe the issue? Thanks for any help on this!
Actually, I managed to solve it manually. I downloaded the zip file and manually extracted the contents to the correct folder and that seemed to work. Perhaps the .exe needs some tweaking? Thanks anyway! Great plugin!
Hello, glad you figured it out, there are still a lot of things that need to be fixed indeed and the documentation is lacking a lot of features and data information. Right now the focus is on adding one last missing feature, toggle timers, then I'll start cleaing up the code a little bit then focus on the documentation because right now is lacking a lot of stuff. Please join my discord server to keep in touch with the future development and get early access to newest builds and details https://discord.gg/2yD6B2PTuQ
MMLTech updated Fly Scoreboard OBS Studio Lightweight Dockable Scoreboard Plugin with a new update entry:
Fly Scoreboard v2.1.4
  • Improved versioning preset for cleaner, more consistent release management.
  • Optimized local webserver health-check, significantly reducing unnecessary polling and improving overall responsiveness.
  • Updated plugin script architecture to support the newly introduced team color system
    (Requires updating your custom overlays to match the new structure.)
  • Added a dedicated Start/Stop Webserver button directly in the dock for faster...
Just started on the scoreboard and getting partially there.
What does this instruction mean? Where should I find this green indicator?
When I show the dock, I get this:
But nothing about the scoreboard. I set home and away teams but am not getting anything.
I looked in some of the folders such as:
and
[EDIT] Same problem as @lockerbycomposite. When I used the zip file to populate the resources directory it worked.
First attempt is looking great after unzipping the resource folder.
My quick observation is that it might be nice to have the "Period" or "Half" timer have an integer value that can be easily incremented as the periods, rounds or halves progress. Minor thing and I will look into the source code to see if I can add that. For now I can just rename the timer from "Round 1" to "Round 2" and then "Round 3".
Thank you!
[edit] I just noticed that the "Score" stat is showing up under the timer as Period. This would be great if I could then just hide the original timer name.
[edit-2] Simply having a blank timer name removes it. This now works perfectly for me but hacking the Home-Score to be the period number is not a great solution. But can't argue with it working!!!
What is the easiest way to reload css edits to an active stream? I tweaked the text color in the timer name (score pill) so that it is not dark text on dark background.
Thank you.
I am not a terribly gifted OBS user, I'm having trouble launching the scoreboard in OBS. Any help with getting it launched would be appreciated.
請問能否調整一下球隊名稱的字體大小?它在我的螢幕上顯示得太小了。
Big fan of this plugin, would love to see it have a few more customization options -- i couldnt get the bars on the circle-theme ray=style to be quite as chunky as id like.
The ultimate goal would be to be able to use my greenscreen cam's silhouette itself instead of a circle-themed one surrounding me, creating the impression that the audio signal was just coming off of my skin. Not sure how that would be implemented but that'd be ideal.
That is just a default theme to show you how the plugin works, you an adjust the scoreboard by playing with the CSS file
Thank you!
This has been fixed in the last version you can now create single value stats to use for such things
Thank you.
Right now every change that's done in the CSS requires a browser source reload
Here is a full guide how to setup the scoreboard corectly
You can do this very easy by tweaking the CSS parameters
I had to spend an hour working through trial and error just to get the plugin to appear in OBS on Windows in the first place. Now that it finally shows up, I have been trying unsuccessfully to get it to connect to the Browser Source. No luck at all.
The documentation is completely contradictory, and I ultimately had to give up. A real shame, because the plugin certainly seemed to have had potential.
Watch the video tutorials I've exmplained step by step how to get it working. I have to mention that I only test on windows since I can not afford a mac yet, so if you are using MACOS you can search TechCoachRalph on youtube he made a few tutorials how to use this plugin on mac
