Scoreboard Overlay and Controller Plugin
Free Scoreboard Overlay and Controller Plugin 5.1.0
MMLTech updated Fly Scoreboard with a new update entry:
Introduce formatting toolchain and CI checks and added WebSocket/server wiring.
Adds a reusable formatting framework: .run-format.zsh, small formatter wrappers (build-aux/run-*) and helper logging functions, plus composite GitHub actions (run-clang-format, run-gersemi) and a check-format workflow that is invoked from PR and push workflows. Updates PowerShell Windows scripts (Build-Windows.ps1, Package-Windows.ps1) to simplify logic, load utility functions, improve error checks, and produce a ZIP staged with the OBS plugin layout. CMake updated to link Qt Network and...
Thanks for creating this tool. Could you add the functionality for tracking a score which consists of two elements rather than just a single element, i.e., when a score consists of Goals & Points? For example : Team A: 1:10, Team B: 2:05 (where 1 & 2 are Goals and 10 & 05 are Points)?
That can be done creating 2 scores and wiring them in the html
Thanks for the reply. If only I was able to "wire them in the html" :). Could you enlighten or help me in doing that? Much appreciated!
MMLTech updated Scoreboard Overlay and Controller Plugin with a new update entry:
Fly Scoreboard 5.0.0
Fly Scoreboard 5.0 is a major update focused on modular sports graphics, simpler control, and a clearer setup experience.
Important changes before updating
  • - Fly Scoreboard no longer creates, selects, renames, resizes, or changes OBS Browser Sources.
  • - Existing OBS sources remain under your control. Add each HTML panel manually as a local-file Browser Source and arrange it directly in the OBS preview.
  • - Templates must be copied to a location where OBS can read and...
Version 5.1.0 Release adds OBS Studio 33 support
Fly Score 5.1.0 adds OBS Studio 33 support and a clearer dock that follows the Sources dock's appearance.
  • Native icon-only footer for reset, hotkeys, information, and template-folder access.
  • Matching Sources background, clearer stat rows, grouped score controls, and scalable outline icons.
  • Live timer displays and scrollable match controls.
  • Information dialog with community links and the 30,000-download milestone.
  • Atomic state saves, fewer redundant updates, safer score...
I can not get your weather app to work even in OBS version 32. The files are all there, but you do not explain how to make it work, dude. So how does it work. I need step-by-step instructions to make it show up. I am not as versed in using OBS as others.
