atkAudio Plugin
atkAudio Plugin 0.36.0
I'm using OBS 33.0.1 and atkAudio 0.36.0 Build: 20261030-192112 UTC.
I'm trying to test out Blue Cat Audios demo version of Oscilloscope Multi. https://www.bluecataudio.com/Products/Product_OscilloscopeMulti/
It has scanned OK but I get a crash when I add it to my pluginhost2
regards,
David
That's good. I can open the Blue Cat Oscilloscope but I get a crash setting the atkAudio Delay to have 7 inputs. This is the first time I've tried that so I don't know if it is a new issue.
regards,
David
regards,
David
If you are adding buses to the layout, there's a bug which allows to add unsupported bus count. Delay Line only has 1 (main) bus. If you need to increase channel count, set the Channel Layout to e.g. Discrete #7.
I am super grateful for this awesome plugin, but do you have any control of the background of the plugins? My eyes only sees all white with a little black for the faders. It's probably my eyes, but I tend to not do much as it is hard to read. I usually magnify it and squint to see it. I am on a mac and have tried different things, but can't find a compromise. It is evident that you are putting in a lot of time and effort to make this plugin that does so much available for free, so it is totally appreciated. Is it possible to fix? Thanks.
Hi! Can you send a screenshot?
I am using atkAudio 0.36.1 Build 20261102-235032 UTC, OBS 33.0.1 and Advanced Scene Switcher 1.37.2.
Summary
Advanced Scene Switcher doesn't use the same targetUuid for a hotkey when switching scene collections and back again thus losing the mapping in atkAudio Midi control.
Details
I have a media player called "Media 1"
I have a macro in ASS called "ToggleMedia1Mute " that has "Register Hotkeys to control the pause state of the Selected Macro" turned on which among others, registers a hotkey "Unpause macro ToggleMedia1Mute".
I then have a MIDI control mapped to that hotkey "Unpause macro ToggleMedia1Mute".
When I change to another Scene collection and back the macro is being de-registered and re-registered thus losing the connection to the Hotkey in your Midi mappings.
I then try to load the mappings but they are still marked as Unavailable and I have to manually reset mappings.
I then saved the mappings again and the targetUuid is changing
"targetUuid": "obs_hotkey:frontend:macro_unpause_hotkey_8",
"targetUuid": "obs_hotkey:frontend:macro_unpause_hotkey_14",
I'm not sure if ASS should be trying to keep the same UID (or if this is even possible) or if you could try to match on targetName if matching on targetUuid fails.
Again thanks for this plugin, it's breadth of capabilities is incredible and was sorely needed.
regards,
David
Summary
Details
regards,
David
Hi, I was not aware of your response until now. Thank You. I did some research and it sounds like it's something with the apple computer. It's certain effects in your plugin. I downloaded apples sound lab and had the same problem. Google said to invert the colors on the Mac system settings. It worked for Au Lab, but not practical inverting the whole screen. Unfortunately, it doesn't work for your plugin. I can see it the same way I see your plugin instead of white it is black. I would love if you could fix it, but understand if you can't. Thank You for trying......I also tried giving OBS more permissions to.
Hi, I was not aware of your response until now. Thank You. I did some research and it sounds like it's something with the apple computer. It's certain certain effects. I downloaded apples sound lab and had the same problem. Google said to invert the colors on the Mac system settings. It worked for Au Lab, but not practical inverting the whole screen. Unfortunately, it doesn't work for your plugin. I can see it the same way I see your plugin instead of white it is black. I would love if you could fix it, but understand if you can't. Thank You for trying......I also tried giving OBS more permissions to.
Ok. As an immediate workaround, you can use those Apple AUs with PluginHost2. Note: by default it inits all buses, so you might want to remove unused buses with the +/- buttons at the end of layout rows in the PH2s Configure Audio I/O window.
